It is currently Fri Jun 27, 2025 6:31 am
PostPosted: Mon Jun 19, 2006 10:15 am
I finish all my guitar necks with gunstock oil regardless of the finish of the guitar itself. I like the look and the way the neck feels and plays.
For my new model I want to try something new. I still want it to be different from the guitar and would like some ideas. What do you guys use?
I had a Taylor before with a very nice, kind of an open grain finish on the neck...wonder what that is?
PostPosted: Mon Jun 19, 2006 11:18 am
Hi Peter. I've done an electric with nitro, a steel string with urethane, and
I just recently french polished my second steelstring neck, but I haven't
strung 'er up yet. I do like the feel though. I grain filled it with sawdust
and shellac first.
I thought I'd try the fp because a lot of folks around here seem to dig it. I
think there was a poll a while back.
PostPosted: Mon Jun 19, 2006 11:23 am
I know Robbie Obrien likes FP buffed out with wax. I'm not sure which wax he uses, though.
PostPosted: Mon Jun 19, 2006 1:41 pm
I just use a little furniture paste wax and some steel wool to rub it out. Then I remove most of the wax with water. This type of rubbing out can be used on shellac as well as many other types of finishes.
PostPosted: Mon Jun 19, 2006 1:48 pm
Robbie, thanks for the input.
I wonder if anyone knows what Taylor uses on their necks?
PostPosted: Mon Jun 19, 2006 11:08 pm
I have been trying out these two -
Minwax wipe-on satin poly, and Flecto natural oil finish. Both leave a beautiful satin, slick feeling finish, I think the oil is easier to do, but not by much.
PostPosted: Mon Jun 19, 2006 11:47 pm
I have two neck finishes I'll use: oil (think TruOil or similar) or FP shellac. That's pretty much it.
PostPosted: Tue Jun 20, 2006 12:35 am
   I use shellac over zpoxy finishing resin. I like the look and feel of shellac and since any finish will eventually get worn through if the guitar is played a lot I like how easy it is to repair.
                            Paul
PostPosted: Tue Jun 20, 2006 2:27 am
I do the same finish as Paul, Zpoxy with brushed on shellac, then after it cures in 10 days, I satin it out with 0000 steel wool and paste wax. Feels great, and easy to fix if it gets damaged. Very smooth neck, and very comfortable.
PostPosted: Tue Jun 20, 2006 2:54 am
Maybe someone could answer a question for me. Would a Tru-oil finish be easy to repair? I have read many times of memebers using Tru-oil for their necks and was wondering.
Philip
aka konacat
PostPosted: Tue Jun 20, 2006 3:33 am
[QUOTE=konacat] Maybe someone could answer a question for me. Would a Tru-oil finish be easy to repair? I have read many times of memebers using Tru-oil for their necks and was wondering.
Philip[/QUOTE]
Philip,
Yes. Depends on the damage of course, but for normal wear an tear you just lightly sand down and apply some more thin coats.
PostPosted: Tue Jun 20, 2006 5:20 am
[QUOTE=TonyKarol] I have been trying out these two -
Minwax wipe-on satin poly, and Flecto natural oil finish. Both leave a beautiful satin, slick feeling finish, I think the oil is easier to do, but not by much.[/QUOTE]
Tony, do you fill the pores with epoxie also?
PostPosted: Tue Jun 20, 2006 7:07 am
Nope - no pore filler on the neck at all, even with nitro - just wet sand the stuff in with 400/600 and a lot of the pores will fill anyway. I use about 8 coats in all, wet sanding 4 and 7. Then after letting cure for a few days, do the rub out with 0000 steel wool, then a couple coats wax.
PostPosted: Tue Jun 20, 2006 11:26 am
Thanks Tony, I think the Fletco its probably pretty close to True-Oil...I'll have to try that and waxing with furniture wax.
PostPosted: Tue Jun 20, 2006 9:33 pm
I don't pore fill the neck, and I don't really try to fill them either. I don't mind the feel at all.
PostPosted: Wed Jun 21, 2006 12:15 am
I fill with Epoxy and then french polish
PostPosted: Wed Jun 21, 2006 5:51 am
terken .. done them both ways, oil/poly everywhere, or just nitro the face.
